Urgent Motor/ Tranny help please!!!
J Dubs Noling
West MI
Help!!!
I just got a line on a 2001 xj motor and tranny for a great price...I wanted to double check that it will bolt into my 92XJ provided i use my sensors, intake, exhaust, etc...
can anyone verify this for me? are the trannies the same (aw4?)
:dunno:
i hope to pick this up first thing tomorrow provided i can get some verification.
thanks much in advance.
XJoshNoling
The Long block is the same; the intake and exhaust may be useable as is - it appears similar to the 91 - 95 setup as far as sensors, etc.
the newer intake is said to boost HP.....I see no reason why it wouldn't fit....the tranny should be an aw4.....if it has the t-case you may want to swap your's out...the newer t-case is a few in longer......if all else fails pick it up some one will need it I'm sure..
good luck
I know that the TJ switched the aw-4 to the TF-999, don't know if jeep did the same for the XJ for the newer years!
