Mike1331
- Folsom, CA
Does anybody else have this issue? I noticed this while flexing on the Rubicon this weekend to check everything out in this shot that it was touching...
I'm scared i'm going to brake a driveshaft ubolt strap and sheer the bolt heads off now.
My front driveshaft ujoint at the pinion is hitting the middle of the control arm. Right at the strap bolts. I don't see how i'm going to fix this short of moving my upper arm w/ different brackets or getting a bent upper controll arm.
I'm running fixed RE uppers and lowers w/ RE drop brackets.
I noticed a buddy on the con this weekend was also hitting in the same spot w/ his radius arms on his mj. His upper jam nut on his driver radius arm was hitting.
