Upgrading an alternator?
5-90 said:
Well over, depending on the weight they're pulling. I've collected data on most common winches, and I may end up making an HTML table out of it one day...
I've seen draws listed for up to 650A at full load, first layer.
Wow! Thats a lot of amps! Isn't that why you use a deep cycle battery? The alternator's main purpose is to assist and charge the battery, right? If you are doing pulls that require that much power, I'm sure you need something more than a high amp alternator. What limitations would I have if I were to run the 120A and dual batteries? One standard and one deep cycle...
