U bolts for Dana 35 rear
WraithKWK
I'm trying to order a set of U bolts for my Dana 35 from Rusty's off road, I have a Rough country 3 inch adda leaf lift.
My XJ is an 89
Rustys sells
MODEL AXLE VEHICLE
UB1 Dana 30/35 YJ Wrangler
UB2 Dana 35/44 XJ Cherokee
UB3 Chrysler 8.25 XJ Cherokee
UB4 Dana 44 FSJ Full Size
UB5 Dana 44 Differential FSJ Full Size
UB6 Dana 35/44 - 10" XJ Cherokee
UB7 Dana 44 F - 10" FSJ Full Size
Can anyone tell me real quick witch one to order. I know ubolts off a 35 wont fit a 44 so it has me a bit confused.
IIRC, the D35 is a 2-5/8" (2.625")axle tube while the D44 is a 2-3/4" (2.75") axle tube. They probably use 2-3/4" for both. I would probably order the UB2 or UB6 for longer thread. Call them and ask them.
Thanks weirdo, appreciate it!
Think I can get away with using the U bolt plates off my old 44 on the 35 or do i have to order new ones
The holes in the ubolt plates should be slotted so that you can use them with both the D44 and the D35 - no need for new ones.
Awesome thanks again Weirdo
