Gary E
NAXJA Member #687
- Elk Grove CA
Aparently they are pretty flexy since they make arb bolts loosen up and Jessies Ox cover, that is more rigid than a stock cover also loosens up bolts.
Andys opinion is that a truss going across the face would be more beneficial than a tradition over the top brace. are there any other opinions to this? I don't know if the loosening bolts signify bending in the x plane or the Z plane.
There isn't much room around the coil buckets so I would probably just run trusses to them, it should still stiffen it considerably. I do have a plasma cutter so making intricate shapes to cut out around the housing will not be too difficult.
and finally in specific tricks to welding to the pumpkin and the Vac disco part?
