90 4.0
ok this is what I have done so far.
4-terminal plug. Connect probe + to terminal A, and - to D. Note reading, which should be in vicinity of 5 volts. (mine is 4.5)Now move probe + to terminal B. This reading should be 82 % of the first(When I try and adjust mine it will not change voltage no matter if I move it up or down).
Do I need a new TPS??? It reads 4.5 Volts on both sides of the connectors.
