mods can delete my other posts ill put em all in here
rc 6.5" la lift kit brand new in the boxes $1100
http://roughcountry.com/jeep_xj_6xla.html
xj dana 44 from a 87 xj 3.55 gears with welded spiders and zj disc swap with tj retainer plates,bearings,seals,pads,rotors,e brake hardware and shoes
$500
5 33" ss truxus mt's mounted on pro comp black steel wheels 3 have 75-80% tread left 1 at 90% and one is brand new only bad is one has a little gouge round the side wall like it was spun against a rock not bad though and one has a tear inside the bead because the retards at pepboys didnt lube it good enough before unmounting it and the rims are like brand new all hold air just fine $850
also a 23spline 231 t-case with a sye from a 97 xj
$200
and a con ferr roof rack 5'x4' had flat straps from a bronco hard top for the bottom that i cut off and welded bars in perfect for the xj and a fresh coat of flat black $250 no gutter mounts
all items are located in chico, ca and im pretty firm on price shoot me a pm or gimme a call (530)354-0196 my name is tim
thanks for lookin
$500
$200
thanks for lookin
