Okay, some updates, but nothing has been done to make it Jeepspeed worthy yet. I'm thinkin' it might be best to get it running and drivable first!
Although no pictures yet.
Got the engine done. Pulled the head and did the work. I know Ken has done it without pulling the damn thing, but I didn't have anything that would work on it. Cal was over and we torqued it down while some work was being done on some other rigs.
Took the seats entirely apart and rewelded the frames. Although they turned out fine, running a two door while using four door seats sucks. Nobody can get into the back seat!
We took it up to Big Bear for the SoCal Fest over the weekend. I found a few other problems that need to be addressed before getting too far into any build.
First, the front 30 is worn out. I'm hoping its just the ball joints, but it wondered pretty badly while driving on pavement.
Second there is some serious drive line vibration.
I have a couple of extra HP 30's sitting around that will get drug onto the rebuild rack tonight. When I tear into it I'll take pictures and show what gets done to it. Although the desire is to build a go fast rig, I want to keep ground clearance in mind, so the truss will be located on top of the axle.
I put the rig up on the rack today to find the vibration(s)....
It looks like the right rear wheel is bent enough to notice, but that wasn't the bigger problem, a bent output shaft on the transfer case was far worse!
Soooo......I put a WTB thread in the SoCal chapter for seats and an output shaft. If I can't find a spare shaft (its a '96 BTW) I'll get a SYE kit from AA and go that route.
Let me get it a bit tighter, then I'll get into the project of making it a go fast rig.
