Tighter outer diameter coil springs
ert01
I currently have the RE1345 lift springs in the front of my XJ... Perfect height, but after I did the Clayton WJ swap onto my D30 and gussets, the coil springs are a bit of a tight fit in there. I just measured with some calipers and they measure at 5.375" OD right now.
I'd REALLY like to get some springs that are 5" OD. (And still yield a similar lift height. Stiffer spring rate would be OK).
Is there a chart anywhere that lists spring coil OD? Or does someone know of a slightly skinnier spring that could work for me?
Thanks!
