thru-hood cowl intake
Wallyman
Anyone ever replaced the rubber flex tube by essentially placing an air filter on-top of the throttle body like a carb setup? To do so given space limitations would probably require a hole in the hood and a raised cowl intake type hood similar to a hot rod from the good ol days. I'm asking because i opened the hood yesterday and my rubber intake line had split due to heat, time, contact with oil, you name it. Split wide open at the TB. So i either go scrounge the JY this week or i go and try to come up with fabbing a way to make the RENIX mount into a 3 or 4 inch clamp on adapter. I dont want to cross deep water crossings, and with a well designed cowl setup, rain really shouldnt be an issue.
at one time I made a similar setup but it was under the hood and went to a home made snorkel.
do you have weight pulling the rubber piece down? like a cone filter just hanging from the rubber piece alone? I had that problem and solved it by adding a bracket for the cone filter to sit on.
Could make your own shaker hood..
