Dr. Dyno
- Al Ain, UAE
MaXJohnson said:I don't doubt your mileage claim, but I'm curious as to how you would explain a mileage increase from a change that ordinarily would not effect fuel consumption. A 5% increase in plenum volume that may contribute to a slight increase in power in a narrow part of the upper RPM band which is a very minor part of your drive cycle. It doesn't add up. Increasing power does not automatically result in an increase in mileage. In fact, more often just the opposite.
My first reaction is that you've made so many changes to your rig that it would be difficult to attribute a change in mileage to a specific modification.
The 62mm bored TB spacer does more than just increase the plenum volume by 76cc. It also increases effective intake tract length by 1" and raises the TB further away from the plenum floor. This allows the intake air to reach a higher velocity before entering the plenum, particularly at low/medium rpm, thus producing a small torque gain. The mpg gain is due to the slightly leaner air/fuel mixture that results from the higher airflow velocity. Think of the spacer as a mini tunnel ram and you'll get the idea about how it works. The helix bore is merely a marketing gimmick.
As for the Tornado, that's completely useless. It has been tested by independent testers and the result was zero HP and mpg gain. The only thing you gain from it is a lighter wallet.
