fdsa487
- El Cajon, a.k.a. The Box
Ok well i found on my Jeep which is a 2000 XJ w/ a 4.5" RE lift, 32" M/T's the only thing that is limiting my down travel in the front is the control arms where they mount to the axel. There is a metal piece above the lower control arm that sticks out from where they mount on both sides and the top of the control arm hits that metal piece and it stops the travel. Is there a name for this? Is this the "binding" i hear about sometimes?
The question that i want answered is, when i get the TNT kit, will this not happen anymore or do i need to cut that metal piece off so that it does not touch the control arm?
Here are some pictures of the piece that im talking about if i was not clear enough in the above paragraphs.
You can see in this picture where the control arm is worn a little bit where it hits that mount above it.
