climberjeep
- Fort Collins, CO
Damn!
:spin1: :speepin:
Dazz said:If you are refering to the 14's, its only a 30 big spline and not 33 spline with different pressure angle then the 70's. The shaft is still 1.5".
mikedashg said:You're going to run 42's on a 30 spline 14bolt? Is that wise?
xjrugger said:When Going to such great size, has anybody expierienced problems with the unibody running such large meats and full size axles? Any pillar cracks or other damage?
Back to the 14 Bolt Bible for You! :read:mikedashg said:You're going to run 42's on a 30 spline 14bolt? Is that wise?
dennisuello said:have you seen a 14bolt shaft? diameter at the splines is 1.59", shaft diameter is 1.351", by the flange - 1.458".
mikedashg said:It was a 30 spline shaft though. I was pretty sure it was a 1.5" shaft too, but maybe I'm wrong.
:flipoff:
xj_punk said:you are wrong. 30 spl d60s are 1.3 something inches. they are about the same size as a 44, but the ff is nice.
just running a regular d60 without 35spl shafts is a waste imo.
