the ultimate dana 30....sell whole or part
shortxjdoug
Chattanooga tn
going a slightly more hardcore direction with her jeep...so the ultimate d30 is up for grabs. most of this stuff is new and never been run. I purchased the ARB used but it was tested by a local 4x4 shop and is functioning perfectly. all of this is in boxes, it is not assembled.
USED ARB- $525
NEW bearings shims and seal kits- $85
NEW Arb compressor- $135
NEW Cryo treated Nitro 4.56 gears- $185
USED RCV axles- $750
steering+brakes
USED wj knuckles and calipers- $100
NEW Upper balljoints- $20
NEW caliper bracket- $10
NEW brake pads- $25
NEW rotors- $40
NEW JKS unit bearing spacers- $15
NEW JKS trackbar bracket- $45
i also have a housing with no upper for another 25$ if interested so you can build the axle
this is very close to 2000 in parts for the ultimate dana 30, all you need to add is an arb switch set, air lines, and steering links
i will sell the whole package for 1850 or will part out for the prices listed, all the new stuff is priced below retail so you wont find it any cheaper around
Sale pending on the arb and gears, wj stuff is sold
Bump for some cheap dana 30 rcvs! Only 5 or 6 rides on the set, over 1000$ new from rcv
