The Dragin' Wagon making it.
shelbyluvv
29 Palms, CA
Short vid of my WJ at Mountianside this weekend.
That thing is a tank man. Nice WJ! :D
Awesome Grand, nice driving too.
Thanks fellas. It is a fun Jeep. The exhaust is stock with a Flowmaster 40 series. The W has a 4.7 V8 too. Only bad thing about wheeling a WJ over a XJ is when this happens nobody has the parts to fix it on hand.
same thing happened to the last w i ran into out on the trail.... course he had a full set of dutchman's in the box just waiting for a cv to blow :D
Can you put xj shafts in that 30? Nice ride!
The short answer is no you can't.
There are a lot of differences between the WJ knuckle, tone rings, unit bearings, and spider gears. That prevent the use of the XJ shaft.
There is a kit to upgrade to the u-joint style shaft but it is $900.
Like I said when this happened. At least now I know where my weak point is in my front end. If I upgrade with alloy shafts and ox u-joints where does this move my failure point? Either the spiders, carrier, or the R&P. All of which will end your weekend right there. New axles are relativley cheap at $70. You can pick up a used set for spares even cheaper.
I will keep changing axles at this point.
Nice Bo! You're lucky there were no beer cans out there to get hung up on. :D
