Ironmanandy
- North Carlolina
Ghost and a few other buddies from Naxja have been hounding me to throw a thread up here about my Dana 34 project that I started a few weeks ago, so here goes.
An aged and extremely experienced 4x4 fabricator once told me: "No matter what you do to a Dana 30 to improve it... Its still a Dana 30 and you are only polishing a turd"
With this in mind Lets make it Shiny as Hell!!!
I have started building my 1990 2 door split window in the hopes of being able to compete in Next years Ecorrs series Class A, My approach is; simple, reliable, Light, Inexpensive, and Practical... to an extent. Since when was practicality any part of this sport?
I have decided to make my front axle have as much ground clearance as possible and still be tough and reliable. I started with a YJ HP D30 housing I had laying in my axle pile and cut the axle tubes off at the Housing. I then dug out an old Waggy front 44 and gutted it.
I imagine you can see where this is going.
Housing: the Idea is to use a dana 30 housing ring and pinion with dana 44, 1/2" wall axle tubes, outer Cs and shafts. I want a beefy 30 spline Dana 30. The dana 44 axle tubes obviously will not fit in the dana 30 housing and will require modification.
Carrier: The D30 carrier obviously will not fit 30 spline shafts and needs modification. The 30 spline side gears will obviously not fit in the Dana 30 carrier and need modification.
At this point I have removed the axle tubes from the D44 and have turned down the d44 side gears to match the dimensions of the d30. Plenty of material remains for strength. I will make the dana 44 side gears work with the spiders so that the cross pin will mount back in and I will fully lincoln lock the carrier. Machining hardened gears sucks because of how hard they really are. Even the toughest sandvik carbide is having a hard time making this work. I have 1 side done and will finish the rest later this week when I get caught up on control arms.
I will post up lots of pics tomorrow of this build up to this point.
