Thanks Eagle
Rogue Sport
Fort Drum, NY
I read Eagles advice on front end shake. My XJ would shake at 54 mph and around certain corners at that speed. I have a 3" Rustys lift with 31" tires.
I went to SandHills 4x4 here in Fayetteville and Lee diagnosed the problem as a bad steering stabilizer. He replaced th stabilizer and then I took it to have the wheels balanced and rotated and a front end alignment. Problem solved and the XJ drives fantastic.
Thanks again Eagle for your advice. I did a search and read through the threads on DW and front end shake.
Rogue Sport
