testing a coil rail
ptimhere
new london, ohio
2001 xj, 4.0.
I'm trying to test the coil rail. I've seen specs ranging from .7-1.1 ohm as acceptable readings from the #2 pin to pins 1,3,4 on the rail connector. Haynes manual says .95-1.1, cherokeeforum says .7-.88.
I'm getting 1.9 across the board. I know it sounds obvious, but is that going to be within acceptable spec on a 200 ohm scale? I'm mostly curious because I'm getting the same reading at all three pins. If one pin was out of whack it would make more sense.
