jeeperjohn
- Temecula, CA
I drew out a wiring diagram for a Taurus fan and made up some written instructions to go with it.
I got it at an electronics supply house in my area. I will look at it after work and give you the manufacturer and part #.jeeperjohn, where did you source a 75 amp relay from? do you have a P/N?
It's a good idea and simple to do. Just put the switches inline with the coil wires to the relays.What do you think about adding a switch to turn off the fans when they are submerged in water?
Here's one source for a 70 amp relay
http://www.keefephttp://www.texasin...ays_rc700112nn.asperformance.com/kprelay.html
My setup is actually wired differently than the diagram I posted.
When I Tried that Link Several Times, this is what I got: "Sorry, we couldn't find www.keefephttp" and that was all.
