Goatslayer
- PA
I have the LOA conversion, D30 front axle, 8.8" Ford rear, CJ springs all the way around, and 2 or 2.5" blocks welded onto the rear axle, all on an 88 XJ.
Bang for the buck, he's recommending Rough Country leaf springs, 2.5" front and 4" rear. The deal with the 4" rear is that we're going to have to grind the blocks off the axle but I have no problem doing that (yes, I'll be very careful with the grinder). Plus if I can rid myself of the rear blocks I can help eliminate possible axle wrap.
He said my current rear springs are factory CJ with an add-a-POS-leaf + the blocks, which is what's giving me about 4" back there. Plus there are shackles as well.
Even though the LOA conversion can give 4" of lift, he's still recommending I go with 2.5" up front. He said that I may be able to eliminate the front shackles if it's too high or just go with shorter shackles if it's too low without them. He did say it looks like factory CJ springs up front but 1 pack has an add-a-POS-leaf and 1 pack doesn't
Talk about retardedness.
We discussed other manufacturers. He said bang for the buck, quality, and warranty wise, Rough Country is going to be my best option. The reason he isn't recommending RE is that I'd have to convert the front to a 2.5" wide spring and my front is set up for a 2" wide spring.
Shocks will be dealt with once the springs are installed and measurements are taken.
Opinions?
Opinions?
