Hey,
I got a Prestone Flush/Fill Kit and I'm confused as to which Heater Hose does the T-Fitting go on.
The instructions say it must go on the Heater Inlet Hose. Which I'm not sure how to identify. Is it the one that runs from the heater valve to the water pump or the one that runs from the heater valve to the Thermostat Housing?
I did a search but I see members using either; so which is the correct hose to use?
btw - 1. When flushing is the engine on or off?
2. How do you drain out the water after flushing by pulling off the
lower radiator hose or other? I'm confused.
Thx, Phil
Thx, Phil
