T case pump
Herb
St. Louis, MO
rats!!! I dropped the pump from my t case and broke off one of the four tabs. is it safe to run with 3 tabs or should i get another one?
thanks
herb
If I recall correctly, those tabs are only used for locating the pump assembly once the rear output cover is bolted on. As long as three of the four tabs are there, it should still locate properly -- though, I would test-fit the pieces to absolutely ensure that this is the case.
If it were me, I'd probably buy another just to be safe. My luck is typically that bad... ;)
No problem, Herb. I hope that it works for you! If you do decide to replace it, 4WD Hardware has the pump housing for sale. It's part number 4338936 (item #33 if you have the picture) and it lists for $49.95.
