RWKHausSupply
- yorba linda, Cali
Bought these for my build and somehow forgot I had them.
These are noted as one of the best if not the best Ball Joints available out there at any cost.
These are brand new and one box was never even opened.
these sell for 250 plus tax/shipping.
You can have them for 200...
Vehicle Applications:
*Jeep Cherokee XJ 90-01
*Jeep Comanchee MJ 86-92
*Jeep Grand Cherokee ZJ 93-98
*Jeep Wrangler YJ/TJ/LJ 90-06
*Jeep Wrangler TJ/LJ Rubicon (Dana 44) 03-06
PPM-4120
Description:
Designed to replace the factory ball joints that are prone to premature wear on lifted vehicles with large off-road tires
Fully greasable metal on metal design
Machined bearing housing made from sintered graphite, bronze, and 1045 steel for a strong, smooth, bearing surface
Ball joint stud made from 4140 steel with an induction heat treated bearing surface for smooth operation and maximum life
Uses a larger stud than stock
Ball joint boot is made from tear/wear resistant silicone polyurethane
Completely eliminates the stock style nylon liner for improved performance and durability
Outperforms the factory ball joint assembly and includes all necessary hardware for installation
Single Set includes: (2) upper, (2) lower
PPM-4120
Description:
