B brandonrob NAXJA Forum User Location Brockville Oct 27, 2006 #1 ok need more info here.... Could my swaybar with bad bushings cause a clunking sound in the front when i trun left or right..??
djblade311 NAXJA Member # 1474 NAXJA Member Location Mission Viejo Oct 27, 2006 #2 it could...disconnect it completely and see if you still get the clunk. Its more likely that its your Trackbar ends, steering, or control arms clunking
old_man NAXJA Forum User Location Loveland, Colorado Oct 27, 2006 #3 Not normally. Most common would be track bar, loose steering box, control arms, ball joints.
B brandonrob NAXJA Forum User Location Brockville Oct 27, 2006 #4 if it is not the swaybar what is the easiest way to test the track bar, stearing box and control arms
S sjbond67 NAXJA Forum User Location mo Oct 27, 2006 #5 just tighten the trackbar at axle end more than likely thats it
