Put in a bracket with a rod or a bolt sticking out that you could slide the end onto after you disconnect it, so it would be like the ones that come with boughten disconnects.
Duct tape. The bungee cord is probably the easiest solution mentioned so far, but copying a setup similar to what's currently available commercially would be the most sound.
I used an eye bolt through the air box and a small bungee cord to hold it up. I could NEVER get zip ties to hold the sway bar up, the heat would just cause the zip ties to fail.
Thanks, I have tried to find pictures of commercial brands but haven't found any yet. I had one setup all figured out but I did it on my shop floor didn't work so well laying in the gravel I need to make it easier.
Thanks for the ideas. Antirocks are nice but I have a total of two dollers in to my disconnect everything else was parts that where laying around the shop. I used a eye bolt under the air box and a eye bolt under the battery box shorten a couple bungee cords and they work great. My XJ is not a daily driver but along with playing in the mud and snow out where I live I also pull a drift boat over to the coast. Front sway bar makes a big difference driving down the twisty roads with a boat behind you. Thanks
How did you build them and for how much lift? I have also seen the zip ties being used. How about trying double sided velcro? I know it will get dirty but hey that what Jeeps do!
