Swap meet
I'll be bringing some "stuff", need to clean the shelves.
SYE: New 00-01 RE Hack-n-Tap, New Blind Flange & used front drive shaft. $100
C4x4 Tow Hooks. Rust on the bolts & clips but the power coat on the brackets is like new. $50
Frt stock skid plate. $20
Trailer hitch $25
3 wheels: Eccos I believe, some rock rash. $5 each make great spares.
Rear quarter windows from a 4 door, dark tint. $10 ea
Dash switches, clock. $2 each.
Front axle shafts, don't ask which u-joint as I don't know :dunno:. They came off of Jes' 93. free
Frt uni-bearings. Used, low miles. Came off of Danno's daughter's DD when she put Warn's part-time kit on. $20
RE 4* steel shims $15
1 set (L & R) rear tail lights: $20
Stock rear bumper: free
i'll take the hitch
Everything for $600 or the knuckles and arms for $400, delivered to Moab.:wave:
I have a few things:
Rubicon Express 4.5 inch XJ coil springs - $75
TJ flares - two front, two rear - never mounted - $40
SOLD AC condenser - brand new - $45
SOLD 5 BFG MT KMs - 33x10.50-15 - well used and some scars, but plenty of tread left - I went to 35s - $100
I have the following, make an offer:
spare tire cover, gray
2 stock air cleaner boxes
front bumper w/end caps, steal blue, 01
rear bumper, steal blue, 01
rear bumper, black, 91
2 dana 30 hubs, 50k mi., 01
2 track bar drop brackets
factory service manuals, 93
wind shield wipers, mopar, blue
dana 30 diff. cover
2 1.25" wheel spacers 5x4.5
3 deg. leaf shims
rear bumper brackets
4 1.75" coil spacers
drive shaft, rear, stock
left front fender, new aftermarket, 97-01
2 coil springs, stock
2 coil springs, up-country
fender flares & brackets, steal blue
lower control arms, stock, 10k mi.
alternator, stock
dana 30 carrier w/3.53 gears
8.25 ring & pinion, 3.53
throttle body spacer
Jet Performance Chip, Stage 1, 96-04 4.0L
dana 30 short axle shaft
dana 30 long axle shaft
tie rod, stock
t-case lowering brackets
power steering gear spacer
2 front tow hooks
spare tire mount, stock
battery cables, stock
dana 35 u-bolts
track bar, stock, 30k mi.
I'll accept any reasonable offer.
I'm staying at the Inca Inn room 121.
I'll be driving a steal blue 01 Limited with IL plate JEEPN61.
Thanks for looking,
Terry
