Paul S
NAXJA Member #103
- Woodland Hills, CA
Super Nerfs - $100
They're scratched-up pretty good, but straight & undented.
I welded them on, when I removed them I cut them off along with whatever they were weleded to, so there is some cutting off of 'stuff' to clean them up, nothing that 10 minutes with an angle grinder won't take care of.
I didn't use & don't have the 4 bolt mounting plates, since I welded the legs directly to the frame. If you want to bolt them on you'll have to make new mounting plates.
The best thing about these is that they are the very last pair of the 'good old style' made by ORGS, they could be worth a fortune when Hinkley passes away:laugh:
Bilsteins - 2 X 5100's, 255/70, 12" travel, $100 takes both.
Paul
Paul
