Mudderoy
- Katy, Texas
Mtb Jak said:dang same problem here... aux fan kicks on.. and its cracked so it vibes like a hoe
Vibrating hoes? Interesting...
Blaine B. said:A/C really shouldn't make a motor overheat. It's putting a small drag on the motor is all.
Ecomike said:IF the E-Fan does not work or the radiator or the water pump is compromized, running the AC WILL quickly add enough heat to the radiator to overheat any engine! Also, an over (or undercharged) AC system can overheat the engine via the condensor which dumps its heat right in front of the radiator.
Once the cooling system is marginal, as in your case, any weak points that leak any coolant at all, like the "Rad or Bot CAP", that fail to hold full system pressure can cause the coolant temperature to run away too.
Muckleroy,
Be sure to use a new cap and new Rad hoses with that new radiator, and you should see it drop down to 210 max.
What part of Houston are you in? I am near S.H./Pasadena.
badron said:You are not overheating because your Efan comes on this is normal operatrion. Don't fix what ant brocken. The fact is any of his temp reading are well with in normal. Don't fix what ant broken.
muckleroy said:Hey thanks, thats a good idea. The cap is pretty new but it makes sense to replace it with the radiator. I'll do the hoses to, wth...
I am looking forward to the new 3 core and putting this chronic problem to bed once and for all. After this I'll do an electric fan replacement for the mechanical, I like the idea of the constant air flow as opposed to the variable based on engine RPM.
muckleroy said:lol Pasadena is the only place I've been where I had a gun pulled on me. Many many years ago. Be careful over there.![]()
Ecomike said:I hope it wasn't me that pulled the gun! :gag: LOL, Just joking.
Lived here since 1978, moved over to this side of town after I go tired of Galleria Westhiemer traffic, where I was born and grew up.
I would stick with the mechanical clutch, yours is obviously still working! It gets tighter as the radiator heat gets hotter and thus runs faster at idle, like direct drive, then loosens up at higher engine rpms and higher vehicle speeds and when it sees cooler radiator air. It is self adjusting.
You will be amased at the new radiator.
langer1 said:True about the load, but the air temp coming off the condenser gets real hot, and all that hot/heated are cuts down on the cool are going through the radiator.
Blaine B. said:Yeah the CSF radiators always seem to have the neck bent. Not sure why. Takes a second to unbend it and it's fine though.
bgred2 said:You guys are making me glad I have an idiot light instead of a temperature gauge................But just to be sure I replaced about everything in the cooling system.
