tetsulo
NAXJA Member #1239
- Western, MA.
I estimate I've put approx 2500 to 3000 miles on my stroker. Today while driving home I had sudden drop in power and the idle became rough. Temp was exactly where it should be and so was oil pressure. I was close to home so I drove it. Let the engine cool off and then started pulling the plug wires one at a time with the engine running to see what would happen (I suspected a misfiring cylinder). Pulling #1 made it worse. Pulling #2 didn't make any difference. I removed SP #2 and found a little bridge built up between the electrodes. I pulled 3 thru 6 and they look fine. #6 is a little darker than 3 thru 5 but acceptable.
#1 was close to completely fouled (black and built up), and #2 was shot. I need to fix this. engine seems to run great which to me means it's not the piston rings right? gas mileage is good. blue smoke is not normally apparent from the rear exhaust...but once in a while I will see some usually if I have been running at highway speed for a while, then stop and accelerate suddenly but even then it's not huge clouds of smoke. Is it the valve seals? the stems? The piston rings?
Sorry for the novel, but I'm trying to explain this as clear as possible.
Matthew
Matthew
