Ok Fellas -- need some imput from you all, particularly any of you who are more than shadetree mechanics...
Leonard over at Tinkers (trialrunner on
) is looking through the engine for me, trying to track down the problem. As previously mentioned, his trained ear and that of a couple of machinists he uses all put my noise at cyl 2 and 3, top end -- those two cylinders failed their compression tests miserably, showing only 35 and 65 lbs of pressure, respectively. Further, there was evidence of pressure bleeding between the two cylinders...
The head is off and has been inspected by the machine shop -- it is warped 0.0014, which I believe is still within factory spec, but the warpage is focused on the front of the head, in their opinion resulting in the compression issues in #2 and #3. Further, while the valves were all seating well enough to pass the water test that Frank and I put them through (Leonard did as well), they did not fair as well under pressure in a leakdown test at the machine shop, both cylinders #2 and #3 showing significant leakage. The machinist recommends planing the head and a valve job, and it is difficult not to agree. FWIW, all springs tested at 240lbs, which is what these aftermarket Crane springs should be at (also allow for additional lift).
So, some progress - However, it does not answer the question as to why I am repeatedly getting bent pushrods - several were bent again when Leonard disassembled the engine, and that is with approximately 15 miles on them. Leonard is somewhat at a loss, as am I. Measurements from the machine shop, and mine, indicate that stock length pushrods should have been appropriate. There is no signs of any valve contact with the pistons. The lifters all appear in fine shape... WTF??
I really don't want to get the compression/head issue resolved, put it back together and end up with a bunch of pushrod related damage -- what say you oh wizards of jeep??
eace:
