Stroker no Start, Need help ASAP
NHxj4x4
NAXJA Member #1132
Keene NH
GUys, I'm in the shop now, and just tried to turn my stroker on for the 1st time. It will not start. I get a very good crank, and some pops and slight smoke out of the exhaust. Also the ait filter makes an occasional wiiissssshhhhh noise. I check all the normal stuff like connections ETC. Any ideas PLEASE>
Todd
93 XJ, 4.6L Stroker, AW4, 231
distributor indexed?
I understand it's easy to have it 180 degrees opposite from the correct spot...
Maybe it is wrong?
OK, I had 2 and 4 swapped, so I corrected that, it still will not start, but the popping and wiiissshhhing is gone now. Does this help diag?
Thanks!
Todd
Did you reconnect ALL your grounds ?
