I hope you guys are bored, cause this is going to be VERY detailed. We'll start with the specs (everything is new unless I say it's old):
93 XJ
97 Block
01 Mani
62mm TB
62mm TB Spacer
24# Furd Injectors (Blue Tops)
93 Fuel Rail w/ stock regulator (old, cleaned really well)
93 Stock Pump (old)
4.6L Stroker
AW4
NP231
Ford 8.8
D30
4.10's
35's
Crane Cam
4.2L Crank
Pacesetter Headers
Magnaflow Hi-Flo Cat
Flowmaster Delta 40
Custom 2.5in Full Exhaust
Stock 93 Disti and CamPS (old)
Accel Brown Top Cap
Accel Plugs gapped stock
Accel 8mm Wires
New Coil
New CPS
New Fuel Filter
New TPS
New MAP
New CTS
New ECU
New Starter
New OEM O2 Sensor
501 miles so far, only 92 Octane, 2 bottles of Lucas so far, 4 oil changes so far.
OK, now for the issues.
1. It takes FOREVER to start, loves to crank, then I let off, try again, try again, and finally, and randomly it will just turn right over like it should without all the cranking poo.
2. It's kinda lackadazical until 2K, then it picks right up until....
3. Once I hit around 3800, it stops, just flutters feels/ sounds like a car hitting redline, like the noise Gran Turismo makes when you forget to shift. This is the one that is REALLY pissing me off. Also, it won't shift when you get to this point, and this is ONLY when the throttle is half way in or so, like when passing and such. When you drive normally, it shifts like a dream, at the correct shift points for easy driving. It does this is all gears.
4. Gas Mileage is an atrocity, maybe 170mi to a full 16 Gallons.
5. When in "D" and at 55-60ish, it goes into 4th, but the RPM's are at 1100 or so, it's basically forcing to to drive in "3" unless on the highway without hills.
What have I done Already?
Re-did the timing 3 times, everytime it has been OK, it is set to OEM/ Stock settings, I have not cut the ears, nor do I really know what that entails. Brought it to my mechanic friend, and he said that he couldn't adjust the timing if the ears where still there. Maybe someone can explain this?
Pulled the cap, and plugs, I noticed some green cap on the leads in the cap, and also a tad on the plugs. Not sure what that is, but it seems odd since it is all new.
Adjusted the shift cable, checked all linkage at the trans, everything was fine. Checked the injectors for leaks, all fine.
Jeep dealer is useless, they actually told me not to waste my money with them.
That's actually it guys, I'm just not sure where to go from here, and what to check next. I've been trying to search, but I haven't really come across my senario to get the answers I need.
If you guys need more info, lay it on me, I really wanna get this thing running correctly.
Thanks!
Todd
93 XJ
97 Block
01 Mani
62mm TB
62mm TB Spacer
93 Stock Pump (old)
4.6L Stroker
AW4
NP231
Ford 8.8
D30
4.10's
35's
Crane Cam
4.2L Crank
Pacesetter Headers
Flowmaster Delta 40
Accel Brown Top Cap
Accel 8mm Wires
New Coil
New CPS
New Fuel Filter
New TPS
New MAP
New CTS
New ECU
New Starter
New OEM O2 Sensor
Thanks!
Todd
