STOLEN: Auburn CA, 4 runner
RenoXJ
Reno, NV
SOrry If this is a repost, Im just getting this out there. Also a reminer
to safe guard your RIG!!
http://www.reno4x4.com/forum/showthread.php/36691-Tim-Hull-4Runner-Stolen-Today-from-Auburn-Hospital
http://www.pirate4x4.com/forum/showthread.php?p=10702290#post10702290
Well, nothing found yet. So here's the Parts List of the truck. Working on trying to get serial numbers for stuff.
D44 front axle with flat top knuckles
high steer
ram assist steering with 8" ram mounted on custom 180 degree bent tube
drilled and tapped steering box
axle shafts by dutchman
C.T.M. u-joints
5:38 gears
ARB locker
warn diff armor
warn hubs
extra box of warn hubs - brand new - still in box
3' braided brake lines
long spline driveline
D60 rear axle
5:38 gears
ARB
warn diff armor
poison spider disc brake conversion kit
2 - 1' braided brake lines to the calipers
39.5 x 13.5 irok super swampers
2 - 16 bolt bead lock 15"x10" rims
2 - 24 bolt bead lock 15"x10" rims
mile marker 8000 lb. winch
120' of synthetic winch line with 12' slip sleeve and 15' of fire line @ the drum end
viking offroad aluminum haws fairlead
big rocks offroad winch bumper specifically for a 3" body lift
Marlin Crawler rear bumper
5" bushwacker fender flares, F&R
2 - 2.5 gallon air tanks by foothill offroad
Marlin Crawler t-case adaptor plate and 2nd t-case
Marlin Crawler cross member with extra mounting hole drilled in drivers side
WFO anti-wrap bar kit
brand new optima red top battery
ARB air pump - old style (not small one)
60" high lift jack painted black
aluminum tailgate toolbox for 4Runner by Jeffco fab - 1 off design
aluminum diamond plate toolbox
3" x 30' tow strap from Foothill Offroad
2 - 2" x 20' yellow tow straps
olive green tool bag ("Tim's Tools" in sharpie)
yellow transparent high capacity air hose 50'
Trailhead air down kit (tire de-flation)
Copra night watch CB
K-40 roof mounted antenna
custom 4 switch aluminum panel for ARB switches - 1 off design
many tools.....
camping gear...... :smsoap:
