blistovmhz
- Vancouver, BC
I'm looking for some input on steering options.
I've smashed my UTK stock bars too many times, and I'm sick of TRE roll.
98 XJ, 6.5" long arm, 33x12", D30, lunchbox.
This is my DD and I do a lot of moderate wheeling. I wheel myself into a lot of bad decisions and large off camber situations (thus the destroyed TRE's). Jeep needs to be safe on highway and has to get me through a day of "oops".
Looking at a few off the shelf options, but may just build it myself.
Currently looking at the following:
1. Rustys OTK - HEIM - http://www.rustysoffroad.com/rustys-conversions-over-the-knuckle-steering.html
I've heard concerns about HEIM's as well as concerns about putting both the draglink and tiebar stacked on the passenger knuckle. Has anyone actually had any issues with heims or had a stacked heim destroy the knuckle?
This setup also uses a rather short tracbar. Again, some guys say it's a non-issue, while other say it tracks like shit. Thoughts?
2. JCR 1tonne OTK - http://www.jcroffroad.com/product/STR/1TNST-OTK.html
As I've got TRE roll, I'm not super hot on the idea of doing TRE's, but as the draglink departure angle is decreased so much with OTK, is roll still an issue?
This kit doesn't come with a tracbar. As I'm only at 6.5" lift and have an tracbar appropriate for stock steering at my height, I don't know if I'll need to relocate the tracbar anyway. If that was the case, I'd probably just go with Rustys 1 tonne setup, given I'll have to contend with the tracbar length anyhow.
3. Rustys WJ OTK conversion - http://www.rustysoffroad.com/jeep-s...j-steering-and-brake-conversion-xj-tj-zj.html
I assume their WJ knuckles already have spacers and are ready for installation. If I went this route, I'd probably source my own WJ knuckles and space'm myself. I know this option is probably the best long term, but it's also the most labour intensive and expensive. Even sourcing my own knuckles, I'm still looking at about $900 for this conversion. Again, this one uses HEIM's as well so same questions as number 1.
So between all three options, what are the pros and cons? Are there other options I should be considering? I'm leaning towards one of the HEIM options mainly because it doesn't require reaming, can deal with larger angles, and cheaper. Someone correct me if I'm wildly off?
