jalehman said:
I was trying to separate the notion that what causes wandering and decreased steering effort shouldn't be associated with what causes death wobble. In my opinion, they are two complete different problems.
You are entitled to your opinion, but if you wish to discuss what I wrote, it would be useful if you didn't misquote me. I never said that low or zero caster
causes death wobble. In fact, I always go out of my way to try to clarify that it does
not "cause[/i] death wobble. That does not, however, mean that increased caster does not help to mask or alleviate death wobble resulting from other causes. Too many people have reported that increased caster
does help for me to ignore it as a factor.
Why? Because of the same reason caster increases steering effort. Think about what caster is. It's the angle between the upper and lower ball joints in the steering knuckle -- what used to be called "kingpin angle" back in the olf days when there was a single rod called the kingpin that held the knuckle to the axle.
When caster is xero, this angle is vertical and it points down to the center of the tires' contact patch on the road. Turn the steering wheel and the front tires rotate around the point where this imaginary line intersects the pavement.
Now dial in a lot of caster. Now the imaginary line is slanted so the lower ball joint is ahead of the upper. The axis of rotation no longer intersects the ground at the center of the tires' contact patch -- it's either toward the front of it, or even entirely ahead of it. What happens now, and why this increases steering effort as well as assisting the steering to return to straight, is that when you turn the steering wheel, in order for the tires to turn you are now forcing the tires to lift up slightly onto one shoulder -- the inside shoulder for the outside tire, and the outside shoulder for the inside tire. The tires' tendency is to run flat on the tread, so when you release the wheel the vehicle's weight makes the tire want to flatten out, and to do that it has to push the tires back to straight.
This same geometry uses the vehicle's weight to dampen and combat death wobble. However, unless something starts a wheel oscillating, there can't be death wobble to worry about. The caster isn't what starts the tire wobbling, even if it does help to control it when it occurs.
In most cases, the actual cause will be found to be tire balance. Other factors, such as worn suspension/steering components, may allow it to get out of hand, but the root cause is
almost always tire balance.
