Steel Tail light kit????
garciaxj88
yuma,arizona
Has anyone put the steel tail light kit from rusty's offroad to there xj? From what i know u have to get a harness and the two tail lenses. To my understanding u need to get the backup light, and brake/tail light, but nowhere does it say anything about the turn signal light. My question is if the harness that u need is for splicing the turn signal into one of the other lights or what? if im correct the stock xj uses three seperate bulbs but then again i havent taken a tail light assembly apart on an xj.
Your blinkers run on the brake light just like with trailer wiring.
if you get them, put your blinker on the bottom and brake light on the top. just put cheap small lights on your bumper as back up lights. then the lights in the boxes can be on the tail light only and they look damn good
