Starting the year off with a "BANG"!
Lawn Cher' said:
And they say the MWC isn't hardcore.
The Sean that broke a JKS arm at Moab wasn't SeanR was it?
I thought it was Sean00XJ or something like that.
I could be wrong though.
Tore down the rear axle last night:
Guess that answers the, "Yea, it's a C-clip axle but have you ever seen a 31 spline 8.8 shaft break?", question.
yeah...
but did your wheel go flying out of the axle?
:D
The news keeps getting better.
Apparently, I tried to straighten the arc of the ring gear teeth that were engaged before the shaft let go.
Add an 8.8 R&P to the list.
daaaaamn
kinda makes you wish you had an extra pinion support bearing huh :D
If the pinion's okay, just change out the ring gear with one from another set.
Check around, I'm sure at least one person has a ring gear from a set they ruined the pinion in.
Wait! You can salvage your damaged R&P! Try this: grind off all the teeth, coat the R&P interfacing surfaces with plastikote or some other such rubberizing product, and set the backlash really tight.
XJ_ranger said:
daaaaamn
Pinion's fine. In fact, it's amazingly fine.
The ring gear teeth that were engaged all bent before the shaft exploded.
The pinion held up to it.
I think I figured out how this all happened.
I was climbing a steep waterfall (sharp rocks) when the front pinion gear let go.
The whole thing dropped a little ways, then the rear tires grabbed traction. All the weight of the dropping XJ was caught by the rear tires/axle.
The results were kinda dramatic.
Judas Priest Brad ... you just about wiped that one clean!
Les
