Sneaky
- Kelso, Washington
I got my flares the other day and was stressing about the instal of the rear so that's where I started today. I thought it out pretty well and was really concerned about sealing up all of the radius cuts. Ill explain what I did step by step.
First I got all my tools/materials gathered.
Then started out by getting the right side of the Jeep off of the ground.
Then took the wheels off
Not too eventful yet, I know...
Had to remove the flare and bumper cap.
Then I removed the door trim so I can trim it down when done and reinstall.
Then I tried to place the flares on the jeep to get my reference lines... Pretty difficult in my opinion so I just started cutting. With some research I had a pretty good idea of how far for the first cut and where to do the radius cuts.
After the first cut I followed it up with a paddle wheel.
After that I had marked all of the spot welds and my cuts I was going to make.
Notice I hadn't marked my cuts in the photo...
To make sure I had a clean surface on the back side for primer and my urethane sealer I wire wheeled the back lip.
Once that was done I sealed it with some self etching primer.
Here's my cut lines.
Then I cut all radius cuts with the air hacksaw. Then followed up with sealer on the back side so that it would be sealed really well once I folded the metal back.
After that I folded back the metal and then did some more sealer and fully capped all the bent back tabs.
