SurfXJSnow
- Charlottesville, VA
the best way I can describe it is a boing/springy noise. not so much a "clunk" but more like the way it would sound if you hit a spring with a hammer? This is on a 01' XJ with a 2" spacer/shackle lift. Its running a stock track bar and control arms. It only happens when going over a bump on the front end. For instance, if you went over a speed bump, you would hear it. The sound comes primarily from the front end, but also seems like it radiates underneath of the driver and passengers seats. Any idea of what this could be? I originally thought it could be the sway bar links hitting the coils up front, but the space between the two looks to be sufficent and I do not see any bare shiny metal where it would be rubbing. It doesnt effect the driving in any way, and the XJ steers straight. Alignment recently done, but the problem has been there ever since we installed the lift about a year ago...
I would like to figure out this problem before we head back to colorado, just to make sure its nothing vital that needs to be fixed.
Thanks in advance!
Thanks in advance!
