i cant get the spring bolts out to put my new re 4.5 rear springs in aaargg!!
is thare a trick ? or do i have to go somewhare that has a torch to heat them up
Soak them with some kind of penetrating fluid, like PB. Do this for a few days and then work on the Jeep. Right now you are just gonna get pissed and break the bolts.
there are access holes in the body that you can spray them from the backside to get the threads. The rear ones, if you are removing the stock shackles, you need to pull the bumper to spray the threads.
