Speed is "ticking" in 89
bzdel2441
I am guessing it is ticking back and forth because it is cable driven but I am wondering if there is any way I fan fix it from ticking back and forth.
Chris
If it is cable driven, remove the cable housing from the back of the speedometer. Pull the cable out of the housing. If the cable is really dirty, remove the housing from the transmission end and squirt some cleaner into the housing from the top to flush it out. Clean off the cable and then coat it with a film of white lithium grease. When re-installing, you will need to twist and push the cable in the housing until it stabs into the gear at the transmission.
I was surprise just how cheap a whole new speedo cable was. It was less than $10 at Autozone. Almost not worth hassleing with.
