Some new budget upgrades....
dellstopjeep
KUNA, ID
my sound bar.... will make going doorless much better
wagoneer tailights and aurora reverse lights... I need the wagoneer clip now anyone???
rear bpe's using the sway bar end links.
bsfab shift linkage idea... about the washers... When I swapped in a ax-15 from a ba10 and then the custom 3 link kit everything moved around a bit so I had to hillybilly it to work... shifts a thousand times better though
and a couple of poser shot since the sun finally showed up showing my newer weld-on rockers bumper and winch.
got my newer 3 row radiator iand geared 30 and 44 axles installed as well. With my rebuilt motor and axles I have more power than ever. Now I wont break down over speed bumps at the mall!
Funny you mention speed bumps at the mall... I broke a motor mount gunning it over one...
