Stumpalump
- Franktown Co.
"I don't need glasses or my eyes are 20/20 so I don't need an eye doctor" I here it all the tiime. I started a new thread because I wanted those not interested in the lasic thread to catch this. You still need to go get your eyes checked at least every other year or at the first sign of trouble or you may go blind. I've seen it thousands of times and it's sad because it could be stoped very eaisily. Two things happen. Tunnel vision or Glucoma is high pressure in the eye. Somtimes it comes on slow or somtimes overnight. The pressure presses the nerves and blood flow to the retina and it dies. This is the most hydiouse disease because your vision dies from the outside in and you don't notice untill you get broad sided or you pull into traffic that you never saw. Everbody needs the pressure test and the cure is common. The other common cause of vision loss is from screwed up blood vessles in the eye. They can grow all twisted and block vision and leak. Diabetics have this bad. They can fix the leaks but it's like fixing rust spots on your jeep with a big hole saw. They just burn the blood vessle ussually leaving a small blind spot. Wait till it's too late and they burn out a lot or all vision. Your retina is the consitancy of wet tolit paper and it dies or gets damage on it's own real easy. Get them checked even if you have perfect vision. One of the worlds largest trade shows is eye care equipment for a reason. You would trade your dick for your eyes given the choice so spend an hour and get them looked at. Oh and protect your eyes when welding and using an Oxy torch because your cornia may get irritated which is no big deal but it's also a magnifing glass that burns the tiny retina nerves a little every time you look at it. The retina clinics are a horribly sad place to visit when you see folks in their prime hoping for a miricle that will never come.`Once it's damaged or dead their is no bringing it back.
