Slow Mj build Thread
Speedbump96
29 palms
88 mj short box
bought it lifted with 10 inchs with rk long arms
dropped it down to about 7.5
Plans
new wheels
Tires
shocks
winch bumper
weld rot in the floor
3m undercoating
new track bar otk
interior roll cag
some other misc b/s
When i first bought it
dropped it two inchs in the front
got the bed pulled
the two major dents that needed to be worked
after we spent some time beating on them
got some new d windows
plans for next weekend
hopefully get the winch bumper on
measure for new front shocks
strip the bed
coat underside of the bed with 3m
well got the jcr pre runner bumper from darky was all mucked up with under coating so me and scott took all the day sanding it down got a good base coat of primer layed down
then we got to some flexing the xj out
Its probably a bit late to tell you now, but right where you straightened the bed near the tail light is VERY easy to just cut right off right at that first body line. Basically, right at the edge of where yours was dented. I did it to my MJ, and even re-rolled the lip to put some stength back into it again. My MJ had some rot going on in that area, but it is also a commmon area that gets all beat up when offroading. People don't even notice that mine is cut off.
Good looking MJ!
Looks good, If you still plan on moving back east I would atleast throw a good coat of paint on the undercarriage before you undercoat it because the salt goes right through undercoating.
That's sharp man, I love the swb MJs. I WILL have one eventually.
Why are new wheels and tires in the plan? The tires look good and the wheels look nice with the white.
He stripped it.
He found a couple cracks and a hacked up cross member and convinced himself it was not salvageable.
Oh well, I got the burgundy dash and A pillar trim.
