Slow Check engine light
JungleXJ
Malaysia
My 94 Cherokee 4.0l HO takes half a minute for the check engine light to come on. Its such a pain to wait for it to come out before I can start it. Its such a pain and is there anything I can do to quicken this up or is something wrong with my ECU unit?
Thanks
Yup it won't start before the check engine light comes on... After the light comes on it starts fine.
Any suggestions what it might be?
it is possible that one of the sensors on the 5 volt circuit is shorting out the system . i would disconnect one sensor at a time, starting with the crank sensor, and see if the check engine light illumnates immediately. which ever one disconnected illuminates the light is the problem. cycle the key each time you unplug each sensor
