Ralph77
- East Coast
So I have been meaning to check my oil pressure with a mechanical gauge. This is the tool I have to do so.
https://www.amazon.com/OTC-Tools-5610-Trans-Eng-Tester/dp/B000R5G0DO
So as some of you know I always come up with these dumb ideas.
This involves putting in a "T" fitting to make is so I can put the mechanical gauge on the Jeep anytime I want without having to remove the sending unit. I figure I have to pull the sending unit to check the pressure so why not set this up when I do so.
I believe everything to be 1/8" pipe thread. I believe the gauge itself to also be 1/8" pipe thread.
So I am thinking using something like this:
https://www.zoro.com/parker-street-tee-brass-18-in-pipe-vs2225p-2/i/G4582103/
Something like this to plug the opening in the "T" where the mechanical gauge would go when not in use.
https://www.zoro.com/zoro-select-he...MI9sTw45qD3gIVw7fACh2KVwWvEAQYAyABEgL4h_D_BwE
Been poking around and have seen where guys have done similar stuff to run both the gauge in the cluster and a mechanical one at the same time.
I don't see a problem with this.
Am I missing something?
