SKIM issues
RDeJong63
Hello new to this forum . Have 2000 Cherokee 4.7 . Twice now the car would start then die , the first time the alarm was going off also . I found a posting on the web
About the wires coming out of the skim module can get weak causing a bad signal to the pcm . I repositioned the wires and it did start and ran fine . 2 weeks later same thing happened ,but no alarm, moved the wires car runs . Is there a permanent fix for those wires available? Or is the only remedy getting the skim delete done on the pcm .
Thanks for the help
