size/thread of stud on top of AC condenser?
cal
Hammertown, USA
Can anyone tell me the size/thread of the stud on top of the AC condenser? The one that usually floats in the tab hanging off of the radiator?
I,m guessing, but 6 or 8 mm.Nut takes 10 mm wrench ? That the one ?
No. This is on top of the AC condenser and slides through a tab hanging off of the radiator.
At least on my rig. There's no nut on it, the stud is there as more of a dowel.
Can not help, can,t get to mine to see or measure it, sorry.
Not sure of the size but mine was a stamped nut. The crappy kind that gets destroyed by looking at it wrong. I left it off. I put a ziptie under the rubber isolat so it kep it pressed against the tab on the radiator and it doesn't rattle or make noise. I may have the nut in my toolbox I'll check after work and if I do I'll measure it for you.
That starts off as an aluminum dowel as you said. It takes a self threading nut that cuts threads into he aluminum. I think the correct socket for the nut is 7/16".
