Site Update
WebTeam
On Thin Ice
On Thin Ice
It may be a bit before it comes back up, but that is completely out of our control.
Seems the organization responsible for .org domain names has changed very recently. They are having some problems at the moment, so our domain is not being sent to the root nameservers. Unfortunately, the timing was bad, as we where right in the middle of updating equipment.
Sooo......Until the LOSERS that screwed up fix it (hopefully very quickly!!).... we are sorta stuck.
Will post any updates as we get them.
Yup, I can give you the IP.... but be fore warned, it will be sluggish, as the forums are still trying to load elements from the naxja.org domain. Your cookies will probably not work, and if you do not remember, or have your password written down.... it will be difficult to post.
A way around that.. put the info in you hosts file, but people that are not comfortable doing so... should not do this. We cannot support user problems arising out of modifying your systems (just a little disclaimer). :)
IP is 207.44.211.211
