Hey guys,
I'm having driveline alignment issues from side to side from my tcase to the rear axle. I've got a 94 xj with iro 5.5 inch lift no tcase drop with a SYE and an 8.25 rear axle. I just changed the motor and transmission mounts and it's about 1-2 inches off from my rear axle yoke. The mounts are the shitty oem replacements. I just changed my u joints in the driveshaft and they're blown again only after a couple months. I've tried quite a bit to get them aligned but haven't had any luck. It's causing crazy vibrations even in 1st from a dead stop. Do you guys have any tips or tricks for it? Or can I get a link to another thread discussing how to fix this? Or is it a common problem that you just deal with by replacing the u joints sooner than normal?
I tried searching but didn't find much for a fix and I'm on my phone at work posting this so it's a PIA to use the search function anyways. Any info is appreciated.
